bobcat 250d nt No weld output
  • bobcat 250d nt No weld output
    Hi. I have a bobcat 250d nt that doesn't weld in AC, DC+ or -. There is still ac generator power and I am able to weld cv + and -. I've check for voltage coming out of the weld generator. There is power on all three wires. The serial number is LC42771. I've check for power coming out of the "AC-Z" and there is power on all leads but lead # 85. Any help would be great. Thanks
    You're missing a digit in that SN.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
      Does it have out put in CV mode? If yes its your stabilizer. If no its either the range or selector switch.
        sorry.. the serial number is lc427441. Yes there is output in cv mode.. That what I figured, stabilizer. Thanks you for the replies.
