Connecting wc1 to millermatic 250
    May have cooked Q52 diode on the 250's board
      Definitely fed 115VAC into the 18VDC trigger circuit if the original wires in the WC-1 weren't disconnected so the damage to the MM250 is now done.
      However, if the WC-1 has SPOT control a slightly different wiring rearrangement would have been required than what cruizer outlined but the necessary end result the same in that the original 115VAC power removed from the picture.
      I highly recommend you not attempt connecting the WC-1/SM-1 to the L-Tec and get the correct setup next time or you're likely to wind up with two dead machines.
      Syncrowave 180 SD
      *HF-251D-1
      *WC-1S & Spoolmatic 1
      PakMaster 100XL
      Marquette "Star Jet" 21-110
