We just had a batch of cylinders fail inspection because there were date stamping's below the radius of the neck. New ruling no marks below the neck including stamping's and dents. I have seen lots of those pass thru here in the last 5 months. So don't buy any used cylinders with those markings. Just passing this on...Bob
High pressure welding cylinder FYI's
explicitly define "radius of the neck". Better yet, can you attach a picture with a diagram label where it depicts this? ThanksHTP Invertig221 D.V. Water-cooled
HTP Pro Pulse 300 MIG
HTP Pro Pulse 200 MIG x2
HTP Pro Pulse 220 MTS
HTP Inverarc 200 TLP water cooled
HTP Microcut 875SC
Bob, is this a new DOT rule or something from whoever does your hydro testing? Thats a heck of a note I tell ya. A lot of people gonna be upset. We have HUNDREDS of high pressure cylinders for breathing air at the fire department. The old ones are solid metal but the newer ones (I say newer...15 year old now) are steel wrapped in carbon fiber. Instead of stamping the hydro dates into them, we have an embossed sticker put on them. Maybe thats the direction this is going.
From what i have been told its been on the books for a while but now that the testing companies are using ultrasound that measure the thickness it shows up. I asked a place that does the hydro test and they won't touch them either. We have about 400 cylinders here and i have looked at the half on the floor. I have seen lots of CO2 cylinders i fill for the beer fans and most of them are stamped on the side. So looks like they will be screwed too...BobBob Wright
http://www.c-f-c.com/gaslink/docs/dot_cylinder.htm Its the 2nd Number 1 close to the top...Bob
(1) Additional information not affecting the markings prescribed in the applicable cylinder specification may be placed on the cylinder. No indentation may be made in the sidewall of the cylinder unless specifically permitted in the applicable specification.Bob Wright
Interesting. I'll be sure to check mine. All of mine come from the same LWS, so if they say anything I can easily say, "well that's how you gave them to me".HTP Invertig221 D.V. Water-cooled
HTP Microcut 875SC
Originally posted by OscarJr View PostInteresting. I'll be sure to check mine. All of mine come from the same LWS, so if they say anything I can easily say, "well that's how you gave them to me".Bob Wright
Some Rejects are being made into bells and gongs
https://www.youtube.com/results?sear...cylinder+bells
My Blue Stuff:
Dynasty 350DX Tigrunner
Millermatic 200
Originally posted by H80N View PostSome Rejects are being made into bells and gongsI just checked 2 that failed and one was side stamped but it was a 1915 model so its too old and the stamping doesn't matter on it. The 2nd one is stamped USN under all of the paint..Bob
Bob Wright
My Blue Stuff:
Millermatic 200
