High pressure welding cylinder FYI's
    Who or who all would be the source of these stampings that placed a cylinders in violation I wonder? It would be a rare customer that would see fit to go stamping on a cylinder. This is a case where the consumer leaves it to the corporations and/or pros.
      From what I have seen it was the orig manufactures, but years ago it may have been common practice. That 1915 cyl I spoke of was date stamped on the side by testers of the day plus the mfg logo. The USN cyl was prob stamped by the cyl manufacturer as per the USN specs of the time...Bob
      Plus years ago it wasn't a violation it was just common practice.
        Yeh, Ive got 7 tanks-bottles. None of 'em have any markings below the shoulder area. One acetylene does have a dig or two tho. It's probably a gonner.
          That's typical with Acetylene cylinders as they are just made from mild steel and not Chrome Molly of the high pressure ones...Bob
            FWIW... Acet tanks are different
            • acetylene
              • Note: Acetylene cylinders contain an inert packing material, which may be agamassan, and are filled with a solvent such as acetone or dimethylformamide. The acetylene is pumped into the cylinder and it dissolves in the solvent. When the cylinder is opened the acetylene comes back out of solution, much like a carbonated beverage bubbles when opened. This is a workaround to acetylene's property to explode when pressurized above 200 kPa or liquified.
            https://en.wikipedia.org/wiki/Acetylene
            • #21
              Thought it was important to point out the rather unusual configuration of ACET Cylinders as opposed to conventional high pressure gas bottles
              • #22
                That's right. I know not everyone knows what's inside one. A guy brought an acetylene and wanted it filled with Argon. That's a no go for sure..Bob
                • #23
                  Yup. Good info to share.
                  • #24
                    Now i am confused as heck. Just got another cylinder back from the same testing company with fresh paint and a new stamp and it has stamping on the side. Don't know if it was a different person that tests but will find out...Bob
                    • #25
                      Good define,Thanks for the information!
