I have a brand new never used spoolmate 200 using it on a millermatic 251 with 100% argon for light aluminum work. Basically 14ga to 1/8" 2" square tubing to make light weight panels and small trailer repairs.
For some reason it will not feed the gas when I pull the trigger. I have it hooked up correctly, direct to the regulator. I have read through the owners manual and I cannot find cause or a cure for this. Has anyone out there experienced this. I dont see and adjustment for the tigger flow or anything at a loss.
thank you
thank you
