What type of plug comes with this welder? The manual says tandem plug. Is this a 20amp or 30amp plug?
Miller spot welder LMSW-52 with timer 230V 2.5kva plug rating?
https://www.millerwelds.com/files/ow.../O716H_MIL.pdf
Not much help though.
The specs state 2.5KVA 30amps 10g power cord so I'm guessing a 6-30p is on the machine.
Ed Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
The plug on the spot welder fits a 6-20p. I did some searching and found this interesting thread. I don't like it that I would need to install a 20amp outlet on a 30amp breaker. That seams it is against code. This thread addresses the issue but I'm not sure how to move forward. I thought maybe someone changed the plug but that seams not to be the case.
http://www.tractorbynet.com/forums/r...tml#post229893
