I had a slight accident happen and ended up cutting the power cord. I'm going to replace the cord with the equivalent but here's the bad part. I removed cover and disconnected the power cord fromy the switch but I didn't pay attention to which line was where. I know green is ground but where does red go? I had it dropped out of the plug because I use it on single phase and I'm pretty sure it matters where red is located on the switch. I should of paid more attention before getting in a hurry. Thank you for any help
Xmt 350 power cord.
Xmt 350 power cord.
Dynasty 400 Wireless
Coolmate 3.5
Synchrowave 350LX loaded with Sequencer on the cooler
XMT350 CC/CV
S74DX Feeder
Optima Pulse Pendant
WC24
30A spoolgun
Neverlast 100 amp plasma with Hyper Duramax torch
Avortec 280 mig
Harris Old school 2 stage Oxy/Ace
Victor flow meters
Flametech Duel flowmeter
Just a hilljack in the woods with fancy welding equipment
and a pet Raccoon.Tags: None
Originally posted by sledsports View PostI had a slight accident happen and ended up cutting the power cord. I'm going to replace the cord with the equivalent but here's the bad part. I removed cover and disconnected the power cord fromy the switch but I didn't pay attention to which line was where. I know green is ground but where does red go? I had it dropped out of the plug because I use it on single phase and I'm pretty sure it matters where red is located on the switch. I should of paid more attention before getting in a hurry. Thank you for any help
HTH
Griff
