I was butt welding 3/8 steel and the only way to get penetration was to slow my travel speed. My settings where off the chart 8 heat 85 wire speed.
The weld looked like crap and i had a high mound bead. This is max metal size so how would you handle this weld. I still have to weld overhead on the bottom of steel. I had scrap piece to practice with and the same result. Until i slowed my hand speed i wasn't getting penetration. When i went my normal speed the weld had porasity sp? I think i might have found problem i was using 030 wire miller says 035 think this is problem?
