Sync 275
  • Sync 275
    Hi chaps, got his Syncrowave 275, Miller tells me it was made in Italy but did provide me with a limited manual, want to connect the unit to a single phase supply (yes I do have my reasons and know the issues), I'm having trouble locating the voltage switching/jumpers mentioned for other welders in this unit, I can't see anything that looks like the jumpers in images of similiar plants on the web. I have some photos of the internals here - https://www.flickr.com/photos/266963...57672725141922 - can anyone give any pointers? is this like any other standard miller unit? Cheers, Sean
    Wow is that fur inside?...Bob
    Bob Wright
      That machine appears to be a single voltage unit - 380v.
      No other voltages listed on the name plate.
      Ed Conley
      MM252
      MM211
      Passport Plus w/Spool Gun
      TA185
      Miller 125c Plasma 120v
      O/A set
      SO 2020 Bender
      You can call me Bacchus
        Are you in Italy and have 50HZ power, cause without changing the primary transformers., its basically a boat anchor.
          I'm in the uk, so if Ed is right then the only way to run it on single phase is some sort of phase converter like these - http://stores.ebay.co.uk/drivesdirec...i.html?_fsub=4 ?
            I"m not familiar with European electrical symbols, but, the name plate seems to indicate single phase. No convertor would be needed.
            HTH
            Griff
