I have a Miller generator 251 nt that fires up and dies out, looking for suggestions on where to start diagnosting, I already pulled the plugs which were all carboned up and black and replaced them, still same result. I was thinking of the fuel filter next? Any suggestions ? Thanks Jeff
miller trailblazer 251 nt
Clogged fuel filter, bad fuel pump, crude in carburetor, low oil level, failed oil pressure switch, bad ignition switch . . .
I'd be looking at the oil pressure switch if the level is OK. You can disconnect the fuel line at the carb and crank it to see if the fuel pump is working.
Last edited by duaneb55; 09-08-2016, 09:35 AM.MM200 w/spot controller and Spoolmatic 1
Syncrowave 180 SD
*HF-251D-1
*WC-1S & Spoolmatic 1
PakMaster 100XL
Marquette "Star Jet" 21-110
