I'm very new to the welding world, just starting my 2nd project. I want to weld steel ball bearings, low carbon, 1 1/4", to a piece of tubing. I've already figured out that the tubing melts, but I have found a way around that. I had already welded 3 of the bearings when someone told me to be careful because the bearing could explode. Now I'm scared to finish with the rest of the 25 that need to be welded. Is this true? I tried searching the internet, but could find only where hollow balls exploded. Thanks for any input! (I should say, these are solid steel, not hollow.)
Will steel ball bearings explode?
Originally posted by ipwallace View PostI'm very new to the welding world, just starting my 2nd project. I want to weld steel ball bearings, low carbon, 1 1/4", to a piece of tubing. I've already figured out that the tubing melts, but I have found a way around that. I had already welded 3 of the bearings when someone told me to be careful because the bearing could explode. Now I'm scared to finish with the rest of the 25 that need to be welded. Is this true? I tried searching the internet, but could find only where hollow balls exploded. Thanks for any input!
Is there somebody out there that knows about Sploding Steel Spheres...??
Methinks perhaps somebody is pulling your leg....Last edited by H80N; 09-06-2016, 12:06 PM..
- 1 like
Originally posted by Aeronca41 View PostA hollow ball bearing just sounds like an oxymoron. Agree with the leg-pulling. :-)
we would send the new guy on an emmiter site out to find a few gallons of "Radar Paint"...and some brushes... to spruce up the facility
worked very time....
http://www.radartutorial.eu/12.scope...20Mode.en.html
- 1 like
used to be on the bombing range.... (MAEWR)
...and I have actually witnessed a young Airman going around the base from shop to shop, guided by people helping him figure out where to get a bucket of prop wash.................
Originally posted by ryanjones2150 View Post....where'd I put that roll of flight line?.
- 1 like
ipwallace
Here is a sculpture I made without any issues.
The solid steel balls vary in size from 1/2" to 7/8" in diameter.
The steel rods are 1/4" diameter.1 PhotoMiller Dynasty 350, Dynasty 210 DX, Hypertherm 1000, Thermal Arc GTSW400, Airco Heliwelder II, oxy-fuel setup, metal cutting bandsaw, air compressor, drill press, large first aid kit, etc.
- 1 like
break one, then weld on part of it afterwards, and the go tell them you didn't believe them so you tried it and show them the pieces and say **** you boys were right. Make sure you get a good look at there faces when you say that. AND if you can, don't grin or smirk when you do it.
- 1 like
