Looks complete to me.
My son has the MM30A with the power pin and block with a Tweco gun.
What gun for M30E Millermatic wire feeder
Originally posted by aametalmaster View PostTweco #2541-2051 should be the pin and block...Bob
http://www.ebay.com/itm/TWECO-TMSAK-...gAAOSwPc9Wzj4q
Don't forget to check your drive roll size. They could be from tiny to 1/8 wire dia. And i do sell skids full of Hobart 1/8" mig wire so it is used alot...Bob
The power pin for the welder is Tweco TMSAK-352 http://www.ebay.com/itm/TWECO-WIRE-F...-/310692020005 Then you will need the adaptor block for the gun to the power pin. The adaptor block has a gas hose hook up...Bob
It doesn't matter to me if I have a miller or Tweco gun,
do you know what part number the Tweco adaptor is?
Thank you for looking into it for me
I looked high up on a shelf at a feeder. Different number than yours but it also has a Tweco adaptor. But the adaptor only fits a Tweco gun. It also has a gas hose hook up where the gun plugs in. Wonder if i could drill a gas hole in yours and add a hose barb? I do have a machine shop also...Bob
I am trying to get the photos to upload full size...sorry for multiple posts4 Photos
Bob,
no there isn't a hole or the gas. I am planning to use for standard home work shop type of thing...so I believe a 200 amp gun should suit my needs.
also do you know why the guy I bought this from added this box and remote gas connection?
Thank you
Bob-just a note of thanks. Many people are benefitting from your new job not to mention your years of experience.
Look inside where the gun plugs in and see if there is a hole for the gas...Bob
His had an old Tweco gun with a square Tweco adaptor block where the gun plugged in and the gas went into the side of the adaptor block. I removed the adaptor block and plugged in a Bernard gun with a Miller pin. There was a hose nub sticking out of the backside where the gun plugged in for the gas hose. I prob have the same feeder on a shelf but I can't see it until Monday...Bob
Found a manual. https://www.millerwelds.com/files/ow...O1235A_MIL.pdf
I helped a shop set up one of those old feeders yesterday. I ordered in a Miller gun but he was running huge wire. Any current Miller gun will fit it. What are you welding for gun size?..Bob
Well that SN doesn't work and the pics are too small to see anything. For me anyways...Bob
