No wire response when I trigger mig gun. The magnetic switch and gas valve as well as power to the weld wire happens. Could this be q10 on ic 204807?
millermatic 210 with spool gun
I have connected 12 volts directly to the drive motor and the motor will run fine. Have shorted q10 across d and s and the wire would run. Still thinking that power mosfet is the trouble.Last edited by yellowsully; 08-26-2016, 09:54 AM.
https://www.millerwelds.com/files/ow...O1325A_MIL.pdf Here is the manual. There is a circuit breaker by the motor drive make sure its pushed in. Sometimes the trigger wire(s) in the gun come loose check that also...BobBob Wright
