(Continuation of previous post: “Overheated Transformer or Failed Power Factor Capacitor, Diagnose & Repair,” in case someone else is researching info on a transformer that ‘delaminated’ not overheated.) Unit is 1954 Miller 61F.
The case has been opened! It is the transformer. Now the question, it is repairable or junk?
The capacitor seems to have leaked a little bit, but I was going to disconnect it anyway.
Thankfully, except for some dirt, the two copper transformer coils look perfect. No melted insulating varnish or other signs of overheating. No visible signs of arcing. I will clean and thoroughly inspect every part of the wiring, if the unit is repairable, but it all looks good so far.
Part of the iron core has ‘delaminated’ because the fabric tape holding it together has become brittle. Just bending a piece 180* causes it to break. One photo shows all the tape down the side just snapped. On the other side, it has completely fallen off. That has caused two pieces of the outer layer to detach on one end, and the plates on the other layers to bulge out a bit.
The top, bottom, and center area (the part surrounded by the copper core), are held in place by the frame and have not delaminated. It is the two outer ‘posts,’ that are only clamped in place at the top and bottom, relying on the tape to compress the layers, that have delaminated.
There is no evidence the pieces that detached contacted anything carrying current and caused a short.
This may be wishful thinking…. If they were only held in place with tape to begin with, would wrapping them with tape again repair the problem?
I know it is not as simple as wrapping with electrical tape and flipping the switch. But I am willing to put some effort into repair, if it’s possible. The 61F is very good quality, and an interesting piece of Miller history. It supposedly has a very smooth arc and would be worth repairing.
I am posting photos of the major parts. I do have higher resolution versions if needed, but these ones may give enough details of the problem.
I really appreciate your help.
Stefen.
Stefen.
