S-64 M System reset
  • S-64 M System reset
    Having trouble resetting my, new to me, S-64 M feeder. I have tried every combination of button holding while powering on possible. HELP, stuck at Program 1 which is lock at a IPM of 240-260.
    Did you look here? https://www.millerwelds.com/files/ow...1585AB_MIL.pdf Bob
      I tried the instructions in section 10-1. Hold both buttons down while turning unit on. I thought it was referring to the mode and parameter buttons, but no change.I never got Setup in the main display as in step 3 So I tried every combination on the unit. The only combo that came up with something different was purge and jog, which gave me the miller logo and software version, I guess. Unable to edit any parameters.
        Could someone please tell me the 2 buttons to hold down to enter setup, mode and parameter select?
          Give Miller a call tomorrow. They will help you out.
          920-734-9821 is their tech support line.
            Problem solved. With a data card I was able to set security lock to off. I now can set all parameters. Fortunately access code was off
              Great! Glad you got it going.
