tig steel vs tig aluminum
  • tig steel vs tig aluminum
    I practice my tig welding in the morning for an hour before I go to work. I notice that the arc is so much quieter and more stable when I switch from aluminum to steel (switch from AC to DCEN of course). All other settings are the same ( I do use gas lens). I did some research and I found this comments from weldingtipsandtricks.com.
    "when you tig weld aluminum, too little flow or too much flow of shielding gas makes a big difference. and just a little too much flow, can make the arc really loud and make the arc erratic."
    I set the flowmeter between 15-20 cfh. Do you change the flow rate between the steel and aluminum? Do you increase the flow rate for thicker metal?
    I leave my gas flow rate at 15 to 18 cfh with either aluminum or steel. And I always use a #8 gas lens.
    Most likely the reason you notice the aluminum welding being louder is because you are welding with AC settings, which is correct with aluminum.
    The DCEN is much quieter, not having the 'buzzing' sound when welding steel..
    Dynasty 200 DX_set up on 3 phase
    Coolmate 3
    MM 251 w/ Spoolmatic 30A
    HTP 625 Micro Cut Plasma Cutter
    Victor O/A Rig
    Bridgeport Mill_3 phase (w/ Acu-Rite 4 axis DRO)
    10 inch South Bend Lathe_3 phase
    Baldor Double Cup Tool Grinder_3 phase
    Baldor 10 inch Buffer
    Rockwell 12 inch Disc Sander
    Cyclone 2ft X 3ft Bead Blast Cabinet
    Quincy 325 2stg- Air Compressor_3 phase
    Graymills Built-in Parts Washer
    Rockwell/Delta Planer, HD Shaper, Uni-Saw etc.
      AC IS louder no matter what you do. I have done lots of both and I don't change mine, I set mine at 15-20, mainly 15 unless I am in a windy room or something with air turbulence.
      DC Is much quiter and you can't even hear the arc but you can hear the gas if its quiet. AC You can dream about hearing the gas and it's allways loud, the higher the frequency the louder it is.
      if there's a welder, there's a way
        Ear plugs
          I listen to music, got the Beats wireless, Bluetooth head phones a few weeks ago, been using them ever since, every day, every time I weld. Sound cancelling the outside and some seriously nice sound. That does it for me, can barely hear the buzz on AC.
            You haven't said what your machine is. I went from a sine wave Dialarc to a square wave inverter Dynasty. In every other measureable sense the Dynasty blows the Dialarc out of the water. Noise is another matter. On higher frequencies I use ear plugs to tolerate the buzz. DC is classical music. AC with inverter technology is head banger, smash the guitar industrial noise.
            Willie
            Dynasty 280DX
            Bobcat 250
            MM252
            Spool gun
            Twentieth Century 295
            Twentieth Century 295 AC
            Marquette spot welder
            Smith torches
              I am using Symcrowave 180SD. Is that a sine wave or square wave?
                I never notice any noise, be it welder, water cooler, air tools, dogs barking, car crashes nearby, etc. Only thing I hear is this..
                Could it have something to do with it? lol
                HTP Pro Pulse 300 MIG
                HTP Pro Pulse 200 MIG x2
                HTP Pro Pulse 220 MTS
                HTP Microcut 875SC
                  Try some Dire Straits/Mark Knopfler.......... Clapton...... Cars...............
                  Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.
                  https://www.youtube.com/watch?v=ENJl...NJlmnqxZUQ#t=7
                  Mark Knopfler's guitar work is unparalelled & the studio work is soooo clean and sharp....
                  the noise floor is so many DB Down.... as to be undetectable............
                    I beg to differ. Kneel before the king. The one person Guitar World refers to as "his royal Highness"...the very first artist to have a Fender Signature Series guitar, even before Clapton, true pioneer of a genre....
                    HTP Microcut 875SC
                      We all have our own personal preferences................................
                      But you might take some time to listen to Knopfler... the studio work... not the live stuff
                        Oh and he even has his own Sharpie marker. Made specifically for him, by Sharpie. How cool is that when signing autographs
                        HTP Microcut 875SC
                          I sure do not begrudge you your choices..... our outlooks differ..... I am a little older... was raised in recording studios and audio labs...
                          back when all that tube stuff was new............
                          As a child..ln the 50's. it was not uncommon for Les Paul to show up at our door bearing pizza and beer .... wanting to pick my dad's brain on some recording problem....you see.... My dad designed and built the first 8 track recording console for Les in the middle of our living room...
                            That is pretty **** awesome.
                              I am lucky... my father was a genius and probably the best audio engineer of the 50's and 60's......
                              he invented and designed many things in the field that are still considered the gold standard....
                              including the "Fairchild 670"
                              http://www.mixonline.com/news/news-p...limiter/377967
                              we lost him a few years ago but his legacy goes on
                              The AES Historical Committee is an international forum open to all who wish to investigate and learn about the achievements of those pioneers whose innovative ideas and inventions have contributed to audio's rich past. Dedicated to the preservation of over a century of audio history, the Committee is developing a broad-based history of audio engineering and the audio industry.
                              he was a brilliant guy and a great dad..... who taught and exposed me to so much
