I have had two of these little TIG welders for more than 7 or 8 years and never saw them work. I got them from the LWS where I work now. I made this brass adaptor for the torch hook up and the gas hose. I bought a new power cable and a 17V torch. Tomorrow I will give them a try. Need to go turn down the brass for the ground cable...Bob
My antique TIG welders.
Got everything hooked up and no arc. The machine was orig computer driven when it was an orbital welder. It has HF inside as I saw a spark plug and a coil. So do I need to run a remote trigger or foot switch? I was just under the impression that it would just weld, but I don't have much tig no how. I can take pics of the inside...Bob
Originally posted by aametalmaster View PostGot everything hooked up and no arc. The machine was orig computer driven when it was an orbital welder. It has HF inside as I saw a spark plug and a coil. So do I need to run a remote trigger or foot switch? I was just under the impression that it would just weld, but I don't have much tig no how. I can take pics of the inside...Bob
looks like Liburdi Engineering Limited bought out "Dimetrics" who look like the original makers of your "Centaur 75" orbital TIG supplies
Maybe they can give you an interface pinout & or manual...............
http://www.liburdi.com/welding-systems-overview
From he look of your faceplate pic I would guess them to be mid-late 1970's vintage
.... should be relatively simple to figure out which pins start the sequence on the "REMOTE" connectorLast edited by H80N; 08-07-2016, 04:59 PM..
Bob
any luck on docs..............???............
Bob............
.... should be relatively simple to figure out which pins start the sequence on the "REMOTE" connector.
