Miller Dialarc HF w/ Power Factor. Ser. # JG097521 which I bought new in about 1986 / 87........Primary use TIG , Water cooled with a Bernard cooler and WP-20 torch. Built many Race Cars with it and just started another Project after it being Idle for about 3-4 years other than just a few minutes here or there.
My eyes have suffered some since the last build and was having some issues seeing the puddle and then installed a 2.0 power cheater in the hat which helped allot...........Been practice welding mild steel CR 1/4" plate to .125" plate using 3/32" tungsten and 1/16 or 3/32" filler rod and not doing to bad but continued to think perhaps the machine was low on output in the middle heat position which is 40-190 even with the fine adjustment Amperage rheostat set a 90-100. As I continued to work on the basics like Argon flow ( 15-20 cf) and different filler materials er70s2 and s6 and 309 stainless getting comfortable under the hood again I continued to feel as though I needed way to much pedal or near 190 Amps to create a puddle just to get started , but then of course once welding it was hard to manage even after I throttled back some as at that setting it would tend to undercut the 1/8" material and the welds just looked washed out with to much heat..........I tried speeding up some but that didn't work either. My feeling was I should only need perhaps 125-140 amps for 1/4 to 1/8" material. I talked with a couple of guys st the store who pointed me towards the RFC-23a foot Pedal which I took apart & cleaned the square 4" tall resistor face some with a stainless brush added a little pressure to the brush assembly and even went back in and reversed the resistor end to end while also changing the white & black wire position.to accommodate that..........which all seemed to help......
Today just when things were looking real good I went back out in the shop just to practice some more and while set in the 40-190 position with the rheostat set at about 70 and the pedal buried , it would not even create a puddle........I increased the rheostat to 100 but still no Joy! Had a weak arc that would not melt the metal. I Switched the lever to High range 125-310 and set the rheostat to 30 and it welded fine , great puddle and great looking welds more like I'm used to. I never really tried the low 40 amp range other than it did have a small arc.
So is there a High / Low Transformer or coil that's out? Is there some more testing I should do to better figure out whats wrong? Could it be the contacts on the levers that went Bye Bye? .................................What say you?
Terry
Terry
