tig welding a crack in a web of cast iron pulley with silcon brass ,how do I set machine ? Lots experience tiging aluminum and steel first time for cast
Thanks
Is this some sort of hard to find part? <br />
<br />
But in general, I'd steer clear of tig welding anything cast iron. You can tig braze it. Without tempting you to try to repair this pulley though, I would suggest aluminum bronze as opposed to the silicon bronze on cast iron in a braze only. <br />
<br />
However, I know of a guy that did an O&A braze repair on a pulley for his lathe. He over built the part then turned it back down. Still holding as far as I know. <br />
<br />
But why not just replace it?
I used stainless for a drill press base, more flex before breaking than regular steel, not sure how the silica bronze works for flex but my drill press is still holding up.
And take your time with it. Let the cleaning action work for you, then flow in your braze filler metal. <br />
<br />
Aluminum bronze has more stretch and I think it's a bit stronger, especially for the cast iron repairs.
I've tig welded cast iron several times with good results. I used certanium cast iron rod. Most recently I tig welded some cast iron bases/floor mounts for restaurant tables. They turned out well.
Lincoln Idealarc 250
Miller Bobcat 250
Thermal Arc Hefty 2 feeder
Thermal Dynamics Cutmaster 52
Torchmate CNC table
