Connectors
If you are talking about frame ground to earth. It is not required unless you using the welder for standby power AND connected to a building electrical system. Welding or work "ground" carries weld current . Only time this should be earth grounded is if you are TIG welding with HF. Remember to follow job site rules. Sometimes they are different than excepted general rules.
Thank you. Now, maybe you know about another question I just asked. What wire to get for a ground? Then, do I hook it to the cart or onto the ground. THEN, how would I do either? I am guessing a lug and a bolt for the cart. But, what about the ground?
Originally posted by Glowzinski85 View PostOk, I FINALLY got my Bobcat 250 on Friday. I've yet to use the thing. I have my cables I made. 2/0 wire. 500 amp ground camp and stinger. Ok, I had thought that the Miller Dinse weld cable connector - male, would go right into the welder. As most of you know, it will not. haha So, I was going to get the lug things. But, my brother and our neighbor, told me about the things that can hook to the welder, using the lug thing, then, have the male connector hook to that. So, what size will fit? As I said, my cables are 2/0. I thought I had gotten 2/0 - 3/0 connectors. I first thought I should just use the lugs. But, using the connector just seems stronger to me.
Thanks for the information
Threaded Stud-to-Female DINSE Quick-Change Machine Converter
[Part# MIL-232728] [Vendor's Part# LDCT-50FA]
$25.67
https://www.arc-zone.com/dinse-connector-ldct-50fa
Connectors
5 PhotosTags: None
