TIG welding rod classifications
    What are you building that you need to smash one to test it?
      Well, I am not going to smash one to test it. I am building a 20 shelf pan rack for a kitchen where they use them to load up the food they prepare, they cook for 2500 people 3 times a day so their quantity is pretty big and the racks that I am making used to be built by Channel, they don't build them anymore but can custom do them for $1000 a piece so I said no thanks, I would rather spend $1500 and build 3 myself for half the price.
      I then also upgraded the shelf thickness from 1/8" to 3/16" as some of the shelf's have been bent on some of the existing racks.
      I don't necessarily need to know how much the shelf itself can hold because a 3/16" angle with a web in it can hold a lot of weight. I am just wanting to know what the filler rod is capable of carrying or a ball park figure so I can safely assume and state to the customer that this shelf can hold "Number" amount of weight.
      if there's a welder, there's a way
        Some plywood cut to the rack size loaded with bricks and you can figure how much it will hold...Bob
          The problem is that it just isn't that simple. The geometric stiffness of a structure doesn't just depend on the filler metal. It is a monumental task to calculate things like this ahead-of-time because then it also depends on load-distribution. Unless you know an engineer that has access to FEA stress-modeling software, you're gonna have to seek the advice of someone who builds things like this for a living, day-in, day-out.
          HTP Pro Pulse 300 MIG
          HTP Pro Pulse 200 MIG x2
          HTP Pro Pulse 220 MTS
          HTP Microcut 875SC
            Got it.
            But not even a ballpark figure, it does not need to be 100% exact. Above 100,200,300,400,500 pounds. Either way, its been in use for a week fully loaded, rolling etc. And so far everything is still fine so my worries may be just for nothing.
            • #21
              I'm sure someone can get you a ballpark figure. I'd help you out if I could, but I'm not an engineer. If you can find the equations for your specific structure and specify all parameters, I can handle the math no problem. I'll leave it up to you.
              HTP Microcut 875SC
              • #22
                Haha, great answer thanks Oscar. How about a drawing?
                Does that work for you?
                • #23
                  Nope, I'm not an engineer so I wont pretend to know how to derive the equations for something like that. They don't appear out of thin air, unfortunately.
                  HTP Microcut 875SC
                  • #24
                    I got it....<br />
                    <br />
                    372 cheese burgers per rack. <br />
                    <br />
                    That's the official tensile strength of your doofloppy there. But thats only one slice of cheese and hold the mustard.
                    • #25
                      Hahaha, sounds good to me.
                      • #26
                        Originally posted by ryanjones2150 View Post
                        I got it....<br />
                        <br />
                        <br />
                        ​I like my burgers without cheese so I guess it will hold a few more...Bob
                        • #27
                          I like mine double meat with extra mustard, so it should hold a few less for me.
                          HTP Microcut 875SC
                          • #28
                            This ain't Burger King here boys.
                            • #29
                              Here are some pictures.
                              • #30
                                Another shot, fully loaded with meatloaf.
