I have wanted one for more than 35 years and just might make it happen this winter when the temp goes down a little more. Was going to do the brick and mortar route but now changed my mind to 1/8" steel plate and build it in the hole. Prob pour some pads in the center and corners. Weld 2" angle along the bottom on the outside. Use diamond plate on the floor. Put 6 threaded all thread holes where the pads sit to level it up. Then 3' x 8' for the sides and 3' x 40 for the ends and tack that all in. Then another 3' on top of that with 2x2 angle around the top for the planks when its not in use. Figured why lay up the walls when I can weld it in. Maybe tar the bottom sheet(s) before its set in place then I can reach down 3' to tar the sides then the top. Maybe some channel stiffeners on the botton and the sides. Just a thought...Bob
I want to build a mechanics pit in my garage.
Bob
here is a pretty good discussion on The Garage Journal Board forums.
http://www.garagejournal.com/forum/s...d.php?t=197150
Originally posted by aametalmaster View PostI have wanted one for more than 35 years and just might make it happen this winter when the temp goes down a little more. Was going to do the brick and mortar route but now changed my mind to 1/8" steel plate and build it in the hole. Prob pour some pads in the center and corners. Weld 2" angle along the bottom on the outside. Use diamond plate on the floor. Put 6 threaded all thread holes where the pads sit to level it up. Then 3' x 8' for the sides and 3' x 40 for the ends and tack that all in. Then another 3' on top of that with 2x2 angle around the top for the planks when its not in use. Figured why lay up the walls when I can weld it in. Maybe tar the bottom sheet(s) before its set in place then I can reach down 3' to tar the sides then the top. Maybe some channel stiffeners on the botton and the sides. Just a thought...Bob
HTH
Griff
We considered building one when we built our garage years ago. Our original idea was to extend the pit all the way out under the back wall of the garage so that if we ever managed to set something on fire an easy escape route would be available fast. In the end we didn't have the money for it but much later I installed a 2 post lift and even though I only have a 10' ceiling so I can only get the car up about 4' or so it beats the heck out of ramps, jacks or laying on the floor for a simple oil change. I mostly use a rolling seat instead of standing up.---Meltedmetal---Meltedmetal
You've probably already considered this, but when I built my garage and discussed a pit with the code officer he asked how I intended to ventilate it. Virtually all solvents, gasoline, propane, and whatever, produce fumes that are heavier than air and will tend to congregate in the pit. I ended up not being able to afford to do the pit anyway, but it was an interesting question. Lots of garages had 'em in 50+ years ago; never heard of one blowing up but I guess it's possible.
Why not a lift instead of a pit? I have two friends that are mechanics. One has a lift and the other has a couple of lifts and a pit. They both say they prefer the lift. In fact, the shop with the pit is about to fill theirs in. Says it's dangerous and takes up too much space.
How big is the are you want to put it?
Originally posted by ryanjones2150 View PostWhy not a lift instead of a pit? I have two friends that are mechanics. One has a lift and the other has a couple of lifts and a pit. They both say they prefer the lift. In fact, the shop with the pit is about to fill theirs in. Says it's dangerous and takes up too much space.
How big is the are you want to put it?Bob Wright
