At max the timer only runs for 3 seconds? What is typical for the maximum run time for a spot weld timer?
Older Miller lectro spot model 11 spot welder
Questions related to performance..............
Did you follow the 1 minute "warm up period"...??
and that galvanized no thicker than 20ga should be spotted in the 1.5kva config...?
tip size dressed to no more than 1/8 in for 1.5kva config...??
per section 8 of the manual
https://www.docdroid.net/G2Jc7se/o74...-9-67.pdf.html
I'm waiting more then a min for the tubes to get warm. The tips and tongs are brand new millers. The combined thickness of the metal is less then 1/8 in. Maybe I this 110v spot welder does not have enough juice and I need to run a 220v?
If I can get 2 more seconds out of the timer I think it might work. The manual says if the timing is short replace the 6p4 tube. Perhaps I need to replace this tube? I checked the connections and they look good after I opened it up. The machine has seen little use.
Originally posted by miller_130xp View PostI'm waiting more then a min for the tubes to get warm. The tips and tongs are brand new millers. The combined thickness of the metal is less then 1/8 in. Maybe I this 110v spot welder does not have enough juice and I need to run a 220v?
also the smaller the tip contact area the more concentrated the heat
see the manual again
What I'm welding is less then 1/8 thickness. I should be getting good welds. I appreciate the help. I'm not sure what else to do.
Maybe I should obtain some wider tips like these
Originally posted by miller_130xp View PostWhat I'm welding is less then 1/8 thickness. I should be getting good welds. I appreciate the help. I'm not sure what else to do.
http://powercustom.com/store/images/spot_welder_tip.jpgBob Wright
Originally posted by aametalmaster View Post
The nose is too wide...Bob
Originally posted by H80N View Posttip size dressed to no more than 1/8 in for 1.5kva config...??
Originally posted by miller_130xp View PostAt max the timer only runs for 3 seconds? What is typical for the maximum run time for a spot weld timer?
the 3 seconds was a rough count. I'll time it with stopwatch to be sure. Also when I run it the lights in the garage dim. I only have it on a 15 amp shared circuit. I'm going to turn of the other appliance to see if it helps. I appreciate the help. I like this machine and hope it can be used for autobody work.
I was reading the manual for the newer 110v spot welder and it calls for a dedicated 30 amp line. It is not clear from the old manual what the amps should be for the line. The line I'm currently using is shared and only 15 amps.Last edited by miller_130xp; 08-11-2016, 12:15 AM.
30 A sounds reasonable. You need a large surge of current for a short time. A 30A circuit would be wired with AWG 10 copper, while your 15 A circuit could be as small as AWG 14. The difference in voltage drop would certainly be noticeable and may starve the machine for power.
Originally posted by Aeronca41 View Post30 A sounds reasonable. You need a large surge of current for a short time. A 30A circuit would be wired with AWG 10 copper, while your 15 A circuit could be as small as AWG 14. The difference in voltage drop would certainly be noticeable and may starve the machine for power.
