Im modifying an engine cross member in a race car. I have a 14 x 1 1/2 wide inch span and need to to install 3/8 steel to clear oil pan. Is there a way to reinforce to stop any flex?
Flat cold roll
If I understand your question correctly, just take a strip of 3/8 x 1 inch steel and weld it on edge to the bottom of the member.
Now you have created a "Tee Section" cross member.Dynasty 200 DX_set up on 3 phase
Coolmate 3
MM 251 w/ Spoolmatic 30A
HTP 625 Micro Cut Plasma Cutter
Victor O/A Rig
Bridgeport Mill_3 phase (w/ Acu-Rite 4 axis DRO)
10 inch South Bend Lathe_3 phase
Baldor Double Cup Tool Grinder_3 phase
Baldor 10 inch Buffer
Rockwell 12 inch Disc Sander
Cyclone 2ft X 3ft Bead Blast Cabinet
Quincy 325 2stg- Air Compressor_3 phase
Graymills Built-in Parts Washer
Rockwell/Delta Planer, HD Shaper, Uni-Saw etc.
