I have an old millermatic 185 in my shop. We've been over using it for about 12 years now, about 4 months ago it started shutting itself down after about 2 hours. It cools down for about 1/2 hour then starts itself back up and is ready for more. A miller rep. was by my shop last week and told me that there is a thermal resistor on the circuit board that can get tired and if I replaced it the machine would be back to its old glory. Can anyone tell me which resistor that is before I tear the thing apart, can't afford the mig to be down
millermatic 185 overheating
It's not 2 hours continuous, the last job it was used on was building an 18' truck bed, weld 4" move down a few rails run another 4" and so on, if i had to guess its probably about 60% duty cycle usage which is pushing the limits of that machine. The rails are 4" channel welded to the outer frame which is 3/16" thick steel. The welder has been used like this for over a decade and until recently didn't seem to mind. That's why I've got a millermatic 250 an
Originally posted by Oldgrandad View PostIt's not 2 hours continuous, the last job it was used on was building an 18' truck bed, weld 4" move down a few rails run another 4" and so on, if i had to guess its probably about 60% duty cycle usage which is pushing the limits of that machine. The rails are 4" channel welded to the outer frame which is 3/16" thick steel. The welder has been used like this for over a decade and until recently didn't seem to mind. That's why I've got a millermatic 250 an
when was the last time the gun liner was replaced or cleaned out......???... Ever..??... Never...??
A dirty liner can cause the wire drive motor to draw more amps and make more heat.... maybe enough more heat to help cause premature thermal shutoff on a machine that is already being pushed to the edge of it's duty cycle....??
A new liner is only $15-20 anyway..........so...........
Originally posted by Oldgrandad View PostSwitched to a Prostar gun not that long ago with the centerfire nozlLiner is good wire runs smooth with no drag, drive roll assembly with tension spring were all replaced about a year and a half ago. I'm running .035 wire.
No it completely shuts down. It is the thermal overload doing its job ( I think), its just doing it sooner than it should. We have a repeat job, it's a base frame for for a fiberglass tank. The frame is made with 1/8 steel sheet and has about 140 inches of weld. We can run about 120 of those inches continuous, About 8 years ago I would use the 185 for that job but after 3 of those welds it would shut down so I bought a millermatic 250 it does that job all day with no complaints. The 185 has been used on other jobs since then and works great, but lately it has been shutting itself off to quickly. A Miller rep came to my shop not to long ago, he thought it might be a thermal resistor on the board. Can I take the board, ohm out the resistors and replace the bad one or is there more to it than that. I have the right people for that kind of repair or is that a waste of time? Ideas? Help please.
