Need a Tig recommendation
Olivero,
Sorry about the mis-name but it sounds like I am not the first to do that.
I once had a friend who was a structural welder and he got a job working inside a barge.
He said he showed up for work the first day and saw everyone except him had their own fan.
The supervisor told him to look at this bulkhead, a large piece of steel wall that had a curvy line along the floor.
The supervisor told Frank to straighten out the bulkhead and walked away.
Frank had no idea of how to do this.
Frank had to tell the supervisor he had no idea of what to do.
The supervisor was frustrated, but grabbed a torch with a large rosebud tip and proceeded to show Frank how to heat an area of the wall.
I forget, he may have sprayed water on the surface, but Frank told me the wall came over to a straight line across that section of the floor.
Super handed Frank the torch and again walked off.
Frank said he finished the wall and it came out straight.
But Frank told me that was the worst job he had ever had. He also quickly bought himself a fan to use down in the bowels of the barge.
I wish I had the talent to straighten out metal, but to me it is an art that I cannot master. Better not to let it warp in the first place.
If I were to do this again I would not use the rotary positioner.
I would clamp it down securely and weld short sections allowing it to cool between passes. Live and learn!
I am supposed to have the JG 232 delivered this week and I will post a pic of it put together.
pgDynasty 200 DX_set up on 3 phase
Coolmate 3
MM 251 w/ Spoolmatic 30A
HTP 625 Micro Cut Plasma Cutter
Victor O/A Rig
Bridgeport Mill_3 phase (w/ Acu-Rite 4 axis DRO)
10 inch South Bend Lathe_3 phase
Baldor Double Cup Tool Grinder_3 phase
Baldor 10 inch Buffer
Rockwell 12 inch Disc Sander
Cyclone 2ft X 3ft Bead Blast Cabinet
Quincy 325 2stg- Air Compressor_3 phase
Graymills Built-in Parts Washer
Rockwell/Delta Planer, HD Shaper, Uni-Saw etc.
FWIW…
ONE of the keys to reducing warpage in TIG is to reduce heat soak…
Some people mistakenly reduce amperage and travel speed in an effort to reduce total heat input to the workpiece
When in actuality you will have a smaller HAZ if you run a higher amperage and a more rapid travel speed
The more quickly you can establish that puddle and move on…. The better off you will be
this is true for light sheet metal as well as plate.
I agree. That is why I should have welded in shorter sections and let the piece cool down between welds, correct?
I put too much heat into the base plate.
Mounted in the positioner chuck, only the 1-1/4 diameter rod I had bolted to the base plate (for the 3 jaw chuck to grab) drew heat away from the metal, and that was almost zero. I should have bolted it to my steel welding table, gone slower and shorter and let it coo in between..
Rather than using a positioner I could have rotated the piece on the table during the time I was letting it cool off. I guess in that situation I may have been better off to put some strips of aluminum bar stock between the plate and table top to eliminate heat transfer to the table.
Or am I incorrect there?Dynasty 200 DX_set up on 3 phase
Coolmate 3
Victor O/A Rig
You did fine.... this was just a general observation .... not a critique................
No worries.
Looks good either way. if its bolted to a strong ridgid surface, it should be fine and might even straighten itself out, it will be under tension but then you don't need lock washers!
Yeah, you weld and learn, that's part of the experience. No good welder did everything perfect every time from first putting the hood on, you always learn something new.if there's a welder, there's a way
Remember your fighting physics, you may be able to use technique to reduce warpage, counteract it or deal with it afterwards, if something warps it doesn't mean you failed (although you may have been able to do better). Either way this is where experience helps, depending on material, joint configuration, metal shape and thickness.
A good discussionRichard
West coast of Florida
- 1 like
If we share our knowledge and experience.... we will all benefit..........................
Pinion, If your bending much tubing of any size , you may find out that having that bender mounted anywhere permanently may compromise the space needed both to start and finish the bend along with the ample room needed for the long bar to gain leverage to complete the bend process. The Hot set-up is a rolling cart mounted bender 3'x3' or 2'x4' cart using a hydraulic ram package to do all the work........allows far greater flexibility in room to finish compound bends of any size.
Tarry99,
I did take that into consideration (length of tube or square material to be bent) when I decided where to mount the bender.
I put 4 stainless steel anchors in the center of the garage space garage floor. That will allow me to bend 8 ft long sections of material.
To remove the bender when I am not using it (most of the time) I will just have to remove the 4 bolts and the anchors remain below floor level
Coolmate 3
Victor O/A Rig
