Millermatic 211 Buying Advice - Part Number 907614
  • Millermatic 211 Buying Advice - Part Number 907614
    So we are considering a newer machine and are looking at the Millarmatice 211 - my understanding is that it is the new model, part #907614
    This machine will be tasked for the following job.....
    Body / Sheet Metal Work
    Frame Repairs - attaching new shock mounts and brackets to frames and axles as needed as well as rust repair on frames.
    Not looking to do what I call " frame heavy repairs " but may need to weld on reinforcement plate as needed in some places.
    Not for a professional shop but for a home garage where the machine may be called to use on average one to three days a week, a few hours in each day.
    Plans are to run it on 240 Volt exclusively.
    Am I looking at an ample machine for the tasks, or not?
    If this is in the wrong place on there forum, I apologize as it has been a while since I have been here!!!!
    THANKS
    THANKS
    It should serve you well..................
    Welds material from 24 gauge - 3/8 in. thick in a single pass. Find Millermatic 211 product specifications, features, and reviews.
      https://www.millerwelds.com/equipmen...-welder-m30024
      Thanks .... are there any concerns I should have about using an inverter machine over what I am used to using, as in machines like the MM210?
      I love the lightweight aspect.
        Nothing the matter with inverters
        I have a bunch of them
        they are a mature technology
        with a lot of advantages
          Thanks ...
          I remember when inverters were first hitting the streets and people were nervous about them.
          I figured they have been out long enough, to be OK.
          Can't way ti pick mine up tomorrow and start buying wire!
          I have an old rear end and some 1/4 metal to stick to it practicing before I get up under a project I am working on.
          Fun days are ahead 1
            If you're worried about penetration, use some flux core or dual shield. <br />
            <br />
            I'm not sure if that machine will spray transfer or not. Might not be big enough.
              <br />
              You just need to watch the duty cycle on that machine if doing bigger parts esp with dual shield. I run .035 dual shield on my MM185 but not everyday. But it does work nice...Bob
