Hi all. I was using our shops Diversion 180 w/auto-line TIG welder. Everything was working just fine. Had to change the gas bottle and when I went back to welding, the gas flow stopped after about 10 seconds without turning the switch off. I held a paper towel up and turned the welder on so the gas would blow it around a little and sure enough, after about 10 seconds the flow stopped. That was with the finger trigger so I hooked up the foot pedal and the same thing happened. I switched over to alum. mode and the same thing happened. The regulator is one with two guages if that matters. Any thoughts? Thanks
Gas stops flowing
