Is it possible to add a Tac, Amp and a Volt meter to a Miller Bluestar 2E if so, should I do it? Would it be helpful?
Miller Bluestar 2e
A digital aftermarket engine tach is easy to install. It's just a sensor wire that wraps around your spark plug wire. Then ground the unit to a chassis bolt somewhere.
Why do you need a digital amp/volt meter on this old welder? If you need more heat, turn the machine up. Less heat, turn the heat down. Doesn't get any simpler than that.Lincoln Idealarc 250
Miller Bobcat 250
Thermal Arc Hefty 2 feeder
Thermal Dynamics Cutmaster 52
Torchmate CNC table
