Miller Syncrowave 180SD welder repair shop in Charleston, S.C.
  • #31
    In my experience, 4-pin DIP (dual in-line pin) packages have often been optoisolators but you really can't tell without the documentation. Did you try two magnifying glasses together as Cruizer said? How about lighting it from different angles to get past the reflection on the coating?
    • #32
      I tried my readers with one thick magnifying glass. Will try two or another pair of 'good' eyes. Thanks for the info!!😊😊😊
      • #33
        May have thick conformal coat on it. It can be removed by carefully lifting it off with a box cutter. then with a little bit of water on top the part, the code can be read.
        • #34
          Originally posted by Mike22590 View Post
          Found Q1. It's a 4 pin transistor? I don't see any part numbers.
          Well Q1 and Q2 control the primary side grounds to transformers T1 and T2 that fire SCRs 2/4 and 1/3 respectively so as such I don't see Q1 being your issue.
          Syncrowave 180 SD
          *HF-251D-1
          *WC-1S & Spoolmatic 1
          PakMaster 100XL
          Marquette "Star Jet" 21-110
          • #35
            Well now that throws a monkey wrench in things😨😨
            • #36
              No disrespect to Duane
              But...
              I would tend to favor Cruizer.... he has been a trained FULL TIME Miller tech for a lot of years..Day in Day out...
              and has an untold number of these repairs under his belt.....
              Not to mention that he has all the Service Manuals and Schematics
              His track record on this board has been excellent.........
              • #37
                Numbers on Q1 transistor: 109007 R9903 3A 6T
                • #38
                  Couple of close hits but no sure fire replacement. It does appear to be an optoisolator - Vishay has some similar-sounding part numbers to the 3A6T. Search both the 3A6T and R9903. Either could be the part number. The 109007 doesn't sound like a part number, but that's just an educated hunch.
                  • #39
                    I'll pull up the diagram on the big screen tomorrow, and have another looksee.. We do know that the pulse transformers are not firing.
                    • #40
                      Before the R9903 there was what looked like a capital I and a symbol.....maybe transistor symbol??
                      • #41
                        https://www.westfloridacomponents.co...rer-logos.html
                        Check this link and see if you can find a matching logo. Will at least get you to the right mfr. if you can find it
                        • #42
                          From memory it looked like either Zetex or Goodark. I'll check when I get home this afternoon. Thanks for the info!! 😊😊😊
                          • #43
                            Hopefully this is legible.
                            • #44
                              Quit legible.... look familiar...??
                              • #45
                                BINGO...!!!
                                109007
                                Darned if it isn't an IR part with an OEM Miller number & $7.40 at Miller4Less
                                http://miller4less.com/advanced_sear...=11&search.y=2
