Hello, I have an older max star 150 STL that has a regular power cord. The newer 150 's have the screw on plugs u can change out from 120v - to 240 Volt. My question is can I order the newer power cord and change it out?One other question is what is the ( CE models) ?I was looking on line at the Miller manual and it mentioned CE. Thanks
Older 150 STL question
Trailblazer 250G
Bobcat 225
Miller 150 STL
Lincoln SA-200
Miller XMT 304
Lincoln Squarewave 355
Lincoln 140C
Lincoln 170T
Miller S-22A feeder
Miller 30A Spoolgun
Miller XR-15
Lincoln LN-25's
Hypetherm 380
Trailblazer 302
Spectrum 875
Just to mention a fewTags: None
its a conformity marking for European markets.
My Maxstar 150 originally came with the 240 plug, looks sort of like a regular plug but with one blade turned sideways...whatever its called. When I got my machine, it had been cut off and a regular 115v plug put on it. I cut that sucker right back off and put what was originally intended back on mine, mostly because I already had an outlet for it that I run my plasma cutter on.
I have no idea if you can take that cord off and put the multi-twister-doohickey plug on, but I don't see why not, although I bet its expensive. What I did was made up a simple adapter pigtail so I can plug it into pretty much anything single phase, cost me about $20 I'd say.
Serial # PLS.....
$99.00 for MVP cord set
As mentioned you can make yer own pigtail adapter for a lot lessEd Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
Thank you for the input. Yes mine also has the one sideways prong.I have made an adapter but I like the new set up Miller has on the newer machines, just unscrew the end and screw on the other. The serial number is LF010121M. Thanks again.Trailblazer 250G
Bobcat 225
Miller 150 STL
Lincoln SA-200
Miller XMT 304
Lincoln 140C
Lincoln 170T
Miller S-22A feeder
Miller 30A Spoolgun
Miller XR-15
Lincoln LN-25's
Hypetherm 380
Trailblazer 302
Spectrum 875
Originally posted by Welder99 View PostThank you for the input. Yes mine also has the one sideways prong.I have made an adapter but I like the new set up Miller has on the newer machines, just unscrew the end and screw on the other. The serial number is LF010121M. Thanks again.
https://www.millerwelds.com/files/ow...42R_PT_MIL.pdf
ITEMS # 15, 40 & 41
you can order them here
http://miller4less.com/index.php
Thank you H80N that's what I was looking for. This site rocks, there's allot of good people here in the trade. Thanks again everyone.Trailblazer 250G
Bobcat 225
Miller 150 STL
Lincoln SA-200
Miller XMT 304
Lincoln 140C
Lincoln 170T
Miller S-22A feeder
Miller 30A Spoolgun
Miller XR-15
Lincoln LN-25's
Hypetherm 380
Trailblazer 302
Spectrum 875
Originally posted by Welder99 View PostThank you H80N that's what I was looking for. This site rocks, there's allot of good people here in the trade. Thanks again everyone.
and we are happy to welcome you as one more.....
