Filler Rod selection AL 4043 or A356?
  • Filler Rod selection AL 4043 or A356?
    I have a housing that is AL 356.0-T430....There is a crack on it. I want to know what is better filler to use on this Al 4043 or A356?
    I think I should use A356 because of similar composition and I believe it has slightly better strength properties.
    I think 4043 is not heat treatable, correct? And A356 is ? ..... Even though I will not be heat treating it, I rather would have A356? What do you guys think?
    I would go with 4943
    Here is an old thread on this relatively new filler alloy
      And another one...
        I would go with that, but I do have have it and need to finish this work ASAP. Therefore, I have to use 4043 or A356 =/ ....any ideas?
          Lacking 4943.... I would probably go with 4043....
          others may think differently
          Can you give us more info... on the casting & your TIG machine ...???
          PICS..??
            4043 i would use in the time frame. I want to try some 4943 but i have to order 16 rolls so if anyone needs 15 LOL...Bob
              Here is the housing and crack. Parent material is AL 356-T430
                Bob...
                the minimum order I have seen is only 5lb for TIG rod...
                think you are talking to the wrong supplier....
                  A356 is a casting alloy specification. Do they even make an A356 welding rod? If so what do they call it?
                  Q: I need to do a lot of welding on A356 aluminum castings. Can you tell me which filleralloy I should use? A: Alloy 356 and its variants (A356, B356, C356)
                  ---Meltedmetal
                  ---Meltedmetal
                    The one I have is spec AMS 4181C ...A356
                      This is what I was basing my assumptions on..you can see filler A356 used with base metal 356 provides better strength and toughness capabilities than 4043....but then again this maybe used for the brand name MAXAL....idk I think I am just going to use 4043 since its been around more.
                        Ron144
                        out of curiosity.... what make and model welder are you using..??
                          Bob...
                          This is straight from Hobart...Bob
                            Bob... pls PM me...... TNX
                              Sorry I can't PM for some reason...Bob aametalmaster @yahoo.com
