So, the Bobcat rebate sparked me to ask this which I have been thinking about for a while now:
My interest and wheels have been turning for a long time now and pondering many times getting an engine drive. I don't do a bunch of mobile welding, but sometimes, although except for this past week that's ALL I've been doing 15 stories on the top of portland cement product silo's repairing all their blown out pipe sections...
I would get a Trailblazer 302D that I thought a few times before and almost bought a few when I've seen them come up at auction, I am however interested in the new 325D having excep power, Pulse TIG, etc. However...A/C tig is unavailable and yes I know that the 302D isn't great A/C tig, but it will do in a pinch.
I am putting in an Allison 1000 transmission behind my Cummins Diesel in my Dodge 2500, thereby I will now have a PTO available. SOOO, I've thought about why don't I just install a 1800 RPM generator head and I can run virtually any equipment I want, even my Dynasty 350 at full power on site, I could run an XMT as well. I have more than enough HP available at idle to run a 20KW generator head on a 2.5:1 PTO. I would burn approximately 1/3 gallon at low idle speed, that's pretty **** small and REALLY quiet compared even to a slow speed Pipe Pro or similar 1,000lb HUGE money diesel engine drive.
For that setup I could even just put my shop equipment in my enclosed trailer and run a lead from the truck having onboard single and three phase power for whatever I could imagine.
Am I crazy? Anyone else run a truck PTO generator?
This also leads in figuring how big a PTO generator to mount, something I've always wondered, as I am NO ELECTRICIAN, I just know enough to be dangerous
...all our equipment is rated for a certain amperage draw @ a certain output @ certain duty cycle, etc. However they rarely list the max draw at the max output, just a time delay fuse rating or a slightly higher normal fuse. Also we always have a higher rating available on 3 phase power, but I can get the same power output (at least that's what the LCD tells me) that I can on single phase? I am making that assumption as the manuals for instance with the Dynasty 350 show the volt/amp curve and putting out 340 ish amps at up to 30 volts but don't say whether it is using single or three phase to produce that curve. Is that just because on 3 phase the duty cycle is better in that it is running cooler???
So if I go ahead and install a PTO powered generator head should I use a 3 phase 120/208 unit??
