I am attempting to weld a tube for a hydraulic cylinder, the top part of the tube is threaded into the rest of the tube to ensure that there will be no separation when welding since the material is over half an inch thick. What type of wire is best used for welding something this size? Flux core or Solid? I am using a millermatic 252 right now which might be a little under powered for the job, and I am using select 727 flux core .45 wire with a shielding gas. I laid down 2 beads on top of eachother and my first attempt left a few pits in the cylinder after it was machined down closer to size. Any tips on the best way to weld something like this?
welding hydraulic cylinders
I like to stick weld or tig weld cylinders. For stick I run 7018, tig er70. Just my preference.MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Lown 1/8x 36" power roller
Arco roto-phase model M
Vectrax 7x12 band saw
Miller spectrum 875
30a spoolgun w/wc-24
RCCS-14
ok so sounds like its most likely just my technique then since its newly machined tubing. looks like i will have to do a few practice runs to get it figured out. Also, with this wire and running argon/co2 mix for gas, do you usually get a decent amount of berries? Only been using this wire for a few months now, the welds come out great but I tend to have a fair amount to clean up. Thanks guys.Last edited by Duffjohn; 05-11-2016, 09:20 PM.
