Hello Gentlemen, I placing my first post, can someone please direct me to the correct discussion trail. I have a wire feeder miller S60 series (s62), Serial Number KE711442, stock 131785 is attached to my shop master 300, I bought it used. I have an issue with NO GAS Flow, I did replace the Gas valve with Miller 222837 GAS VALVE KIT and still Have no Gas Flow, When I press the Gun, the machine does feed the wire, the issue is just the NO gas flow, Can can some one assist with this?. AT first I thought It could have been the female 8 pin connector so I attached a "different" wire feeder to the Power source (SHOP 300) it did work.
S62 Wire Feeder , no gas
Great, Cruizer As it turns out, I tested the feeder on another power source and the solenoid did work.....I checked my shopmaster 300 14 pin connector and I a not getting the 24v reading from A and G. Could it be the same thing a Relay in the shopmaster?
Then I'd guess that youve either dropped a phase, really low phase on the shopmaster, or its set for the incorrect input power. A to G should be around the 26 Volt mark, any less than 20, and you;ve got problems May also have a popped 24 Vac breaker, though thats not likely the case as the drive rolls on the feeder work.
