My 350lx will do anywhere from 5-20 tacks on AC then only the high frequency pilot arc will work, no welding arc. If I shut the machine off for a few seconds it will work again for the same amount of tacks. The arc will also cut out mid weld sometimes. Anyone had this problem?
350 syncrowave performing 5-20 tacks then not lighting arc
Check & clean your ground/work connection... And Clamp
Also try another "Known Good" TIG torch.... they have been known to croak from use and abuse... especially the flex headsLast edited by H80N; 05-02-2016, 12:53 PM..
Originally posted by H80N View PostCheck & clean your ground/work connection... And Clamp
Originally posted by samuel joff View PostNope, I didn't face any issue yet. Everything is goes well so far.
??............. So you checked those things..??.
Originally posted by samuel joff View PostTrying if I found any issue will let you know..
