not putting out AC
  • not putting out AC
    I am new to this forum and I have a question and a problem. I have a old AEA200L miller welder generator Serial #K209205 and it is only putting out about 40 volts. No burnt smell and IO did try to excite it witha 12 volt battery but this did not help. Does someone have a manual for this welder or any idea of where I can start to look for the fix?
    Thanks for the help
    woodmanaas
    I am new to this forum and I have a question and a problem. I have a old AEA200L miller welder generator and it is only putting oput about 40 volts. No burnt smell and I tried to excite it with a 12 volt batterybut this did not help. Does anyone have a manual or a idea on where I can start to look for the fix?
    serial # K209205
    Thanks for the help
    woodmanaas
      Download your manual here
      Find replacement parts and receive detailed answers to your questions by downloading owner's manuals for your Miller products.
        You're missing a letter in that SN.
        Syncrowave 180 SD
        *HF-251D-1
        *WC-1S & Spoolmatic 1
        PakMaster 100XL
        Marquette "Star Jet" 21-110
          If it's to old for the Miller manual site I have a older manual pdf.
            I emailed two manuals , let me know if you get them and can open them.
              Did you correct & doublecheck the serial # and try the download again..??
                Well if it puts out 40 volts, there is no reason to re excite it, perhaps check the RPM via frequency taken at the auxillary terminals, high idle no load.
