I just got a Millermatic 211. I've confirmed everything is connected properly. When I begin wleding, I can weld a few seconds (maybe 3 or 4 beads), then the machine shuts down, amd turns back on. I can then weld for a couple of seconds again.
No problems just holding the trigger down amd letting wire feed. Only have a problem when actually welding.
Welding steel with a 75/25 mix, using a regular outlet. Any help would be appreciated!!
Also, for anyone else with this machine, for the grounding wire, the end that plugs into the machine, there are 4 tiny holes, but only 2 connectors coming out. Is that correct? Thanks!
