What's up everybody, my name's Austin and I'm 23 from NJ. I've been Welding for a few years now but recently got into TIG Welding which I enjoy. I have a Miller Syncrowave 250 and I'm having a few issues with it, I think the high frequency isnt working as it should. On 1/16 aluminum running a few practice beads (100% argon, 3/32 E3 tungsten and aluminum filler rod) I have to scratch start it almost all the time, welders set to AC amps are around 50-65 and HF is on continuous. Any suggestions would be a big help! Thanks
new guy with some issues...
Originally posted by blackedoutfx4 View PostWhat's up everybody, my name's Austin and I'm 23 from NJ. I've been Welding for a few years now but recently got into TIG Welding which I enjoy. I have a Miller Syncrowave 250 and I'm having a few issues with it, I think the high frequency isnt working as it should. On 1/16 aluminum running a few practice beads (100% argon, 3/32 E3 tungsten and aluminum filler rod) I have to scratch start it almost all the time, welders set to AC amps are around 50-65 and HF is on continuous. Any suggestions would be a big help! Thanks
plug in your serial number and download your manual here
https://www.millerwelds.com/support/manuals-and-parts.
- Likes 1
Thanks, I've never heard of that before. I entered the SN on Miller's website and it came up with no results. Its KE657794. I'll have to do some more digging and see what I can find. As far as gapping and cleaning is that hard? When I take the side panel off everything is pretty easy to get to, I just don't want to mess anything up.
Originally posted by blackedoutfx4 View PostThanks, I've never heard of that before. I entered the SN on Miller's website and it came up with no results. Its KE657794. I'll have to do some more digging and see what I can find. As far as gapping and cleaning is that hard? When I take the side panel off everything is pretty easy to get to, I just don't want to mess anything up.
https://www.millerwelds.com/files/ow.../O353J_MIL.pdf
there have been many threads on this....
do a search on "spark gaps".
- Likes 1
Originally posted by blackedoutfx4 View PostOkay I found the manual and I see how to set them, I'll give that a shot and keep the thread posted. Thanks again!
lots of conductive dust collects in and around weldersLast edited by H80N; 04-23-2016, 10:57 AM..
Yes check the point gap & make sure they are clean, then post back with results. Does the high frequency work when set to start & using dc-? Does it work when set to continuous after you scratch start it in ac? Using a foot pedal remote?
Welcome to the forum. I am also from NJ, in the Hackettstown area.Last edited by MMW; 04-24-2016, 04:39 AM.MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Lown 1/8x 36" power roller
Arco roto-phase model M
Vectrax 7x12 band saw
Miller spectrum 875
30a spoolgun w/wc-24
RCCS-14
Originally posted by cruizer View PostGoing to guess and say that you don't have a remote of some sort. No remote and no high frequency.
Originally posted by blackedoutfx4 View Postyes this machine has both foot pedal and thumb control, I use the foot pedal more though and both output contact and amperage control are set to remote, also I was running the high frequency on continuous with the dial at 100 and it was on AC
any luck with the clean and regap...??.
Originally posted by blackedoutfx4 View Posthavent tried it yet lol, still trying to find my feeler gauge. might have to end up borrowing my buddies I checked them out though and they were pretty **** close together and looked fairly clean. according to the manual they should be gapped to .008
will give a bit stronger spark with a wider gap....
once set.... you should get a nice blue spark across both gaps.
I work at an auto repair shop...3 guy shop. We have the owner who does the business end and wrecker driving. Myself who does most the welding and all the mechanical repair and then the paint/body guy. My old a/bp 330 would get bondo, paint and lots of other body shop related dust on the contacts...had to clean once or twice a year till I quit using it. Just dust and dirt would create a path and the hf would start acting up.Last edited by Michael ray; 04-24-2016, 09:38 AM.blue stock,
miller shopmaster 300, s22a feeder, s30 spool gun, hf251, arc pig
miller maxstar 150 STL
miller maxstar 210
miller a bp 330
non blue,
Lincoln weldanpower 150 1982 model
esab plasma
Hobart ironman 210, spool gun
victor oxy acy set
thousands of snap on tools, 3 large boxes and tons of automotive equip.
