i don't think mine has points, it has the newer style coil?
250g trailblazer shuts down after 5 mins
so i got an hour of time to play with it today, running it has 13.9 volts across the battery terminals, it does not lose power to the positive side of the coil when it loses spark, and the test you preform putting the positve lead of multimeter to the negative lead on coil and negative lead to ground checking for voltage while turning the flywheel by hand came back as follows.. cold battery voltage to 1.4 volts after running and immediatly after dying battery voltage to 2.6, i pulled the condensor to look for a part # to match it up and could not find any... will pull the coil and double check that in the near future
