Theading TIG rod thought fingers
  • #31
    I bet it ends up looking like a normal tig weld...just tap button for a little more as needed
    blue stock,
    miller shopmaster 300, s22a feeder, s30 spool gun, hf251, arc pig
    miller maxstar 150 STL
    miller maxstar 210
    miller a bp 330
    non blue,
    Lincoln weldanpower 150 1982 model
    esab plasma
    Hobart ironman 210, spool gun
    victor oxy acy set
    thousands of snap on tools, 3 large boxes and tons of automotive equip.
    • #32
      Maybe you could try a second foot pedal to control your wire feed and test out your dexterity?
      ---Meltedmetal
      • #33
        That sounds like a challenge...kinda sounds like we are engineering a fully manual mig
        blue stock,
        miller maxstar 210
        miller a bp 330
        non blue,
        esab plasma
        victor oxy acy set
        • #34
          I do have an ultra crappy mig that I forgot about...it's a little Flux wire with just high and low. It does have an adjustable wire feeder in it though. I may kill the transformer in it and just power the drive motor and switch and use it for a tig wire feeder. It's small enough to be perfect maybe... that'll keep me from having to change out the wand on the s22a..keeps me from having to use the shopmaster to power the feeder also.
          blue stock,
          miller maxstar 210
          miller a bp 330
          non blue,
          esab plasma
          victor oxy acy set
          • #35
            That's how auto feed TIG robots work, but the wire feeds in though an opening in the cup.
            P.S. No one should be rude to anyone until they know them, as they maybe packing. Also I'm not as good as I use to be. Arthritis, carpal tunnel and lose of close vision (I use 3.25 magnetifiers for work under a foot) have taken there toll on me, but out of 10 welders l work with, I can out work 8 (2 with my eyes closed). The best things I have learned is that my aluminum welds shrink 0.02", copper pulls heat out my welds the quickest, I weld from outside open edges to formed corners, I tack a lot so I don't have to skip or back step weld (thats to slow, as I now know how to control the heat). That 1 amp per 0.001" material thicknesses rule is one I never heard of. It is about right for steel, stainless & aluminum with helium gas, but I would double it for aluminum with just argon gas (even using a Dynasty).
            • #36
              I want this thing...<br />
              <br />
              http://youtu.be/tZyntkRFXto
              • #37
                I agree, and really thanks for the topic. I really do appreciate the subject here. I think a wire feeder may really benefit myself at my job. We do lots of body repair and panel replacement so I really am excited to try it. I wish I had some input for manually feeding but I really don't. I had to pick a piece of filler up and watch my movement after reading this. I guess I just got used to the help of gravity on horizontal welds and found myself pinching with 2 fingers and using thumb to hold while the 2 fingers move...never really had thought about it much till today.
                blue stock,
                miller maxstar 210
                miller a bp 330
                non blue,
                esab plasma
                victor oxy acy set
                • #38
                  <br />
                  https://www.youtube.com/watch?v=tZyn...ature=youtu.be
                  • #39
                    Sweet....I want one too
                    blue stock,
                    miller maxstar 210
                    miller a bp 330
                    non blue,
                    esab plasma
                    victor oxy acy set
                    • #40
                      I'm gonna work on the poor boy version tomorrow
                      blue stock,
                      miller maxstar 210
                      miller a bp 330
                      non blue,
                      esab plasma
                      victor oxy acy set
                      • #41
                        I bet it's cheap. Probably only costs a couple bucks.
                        • #42
                          Mines going to be cheap...that's the only way I can do it. Mine probably won't have the results that the pro model does but then again it might. I have a plan if it needs to pulse and have a plan to make it pulse the wire at different speeds. I'll start building something tomorrow and I'll take pics of what I use and pics of the progress...4 hours ago it was a simple wire feeder, now I have all kinds of ideas.
                          blue stock,
                          miller maxstar 210
                          miller a bp 330
                          non blue,
                          esab plasma
                          victor oxy acy set
                          • #43
                            Well when you're done with it, I'll give ya a couple of bucks and we can make it mine.
                            • #44
                              Let's see how it goes...usually when I do a project like that, if it works, I'll usually build a second or third. I do pretty well in the Chattanooga area fixing gas welders and I buy and sell a few on the side. If it works good and is cheap to make why not?? Worse thing I see happening is possible current backing up the wire...I really don't see that being a problem since the feeder will be isolated from any conductors. If it works i wonder what is the best way to video it. May tape a fixed lens to my phone camera so I can get it on you tube.
                              blue stock,
                              miller maxstar 210
                              miller a bp 330
                              non blue,
                              esab plasma
                              victor oxy acy set
                              • #45
                                Didn't get very far on that feeder today....Monday and I think it must be close to a full moon....I will get it done but as usual I got behind
                                blue stock,
                                miller maxstar 210
                                miller a bp 330
                                non blue,
                                esab plasma
                                victor oxy acy set
