Noob question on shielding gas here, I have been welding for several years with C25 gas on a MM211 with good results. I recently picked up a MM252 and want to give spray a try for those occasions when I work with 3/8 + plate. I never had a need to change from C25 with the 211 however, like anything when you have the ability to do something, the need seems to arise more and more often. Question is, I have read that 90/10 and 98/2 both work with spray, could one of the two be considered a general use gas over the other that would produce good results on 16 guage up to 3/8 material? I already have an oxy rig, pure argon for tig, and C25. Would like to not add another bottle to my already limited space.
Shielding gas recommendation
Originally posted by Unibit View PostNoob question on shielding gas here, I have been welding for several years with C25 gas on a MM211 with good results. I recently picked up a MM252 and want to give spray a try for those occasions when I work with 3/8 + plate. I never had a need to change from C25 with the 211 however, like anything when you have the ability to do something, the need seems to arise more and more often. Question is, I have read that 90/10 and 98/2 both work with spray, could one of the two be considered a general use gas over the other that would produce good results on 16 guage up to 3/8 material? I already have an oxy rig, pure argon for tig, and C25. Would like to not add another bottle to my already limited space.
this manual explains a lot of the process and physics
http://www.awssection.org/uploads/lo...Gas_Manual.pdf
Thanks for the link, good info. If I understand the content correctly, the higher argon content will help stabilize the spray weld puddle while CO2 maitains arc integrity. Sounds like I may have trouble with keeping the puddle fluid on low amperage welds. I guess I am getting another bottle if I want to spray.
