Cutting tip
Originally posted by Marksman View PostI know this might not be the best place to ask this but can somebody tell me what you do with this tip? I have seen a lot cutting tips when I worked for my dad but he passed away recently and I never has a chance to ask him how to use it and what it is used for.
[ATTACH=CONFIG]n567550[/ATTACH]
http://www.weldingtorchparts.co.uk/a...ing-torch.html
http://www.bobthewelder.com.au/Sheet...SM-26-032.html
- 1 like
Always happy to help if I can.....
Oxy-fuel Sheet Metal nozzle
---Meltedmetal
I recently acquired one of these tips with a bunch of other stuff. I e-mailed some questions about it to Victor and was answered by John Henderson, product manager for gas equipment, who wrote this:
The tip you are describing is our type 110 Drag Type cutting tip
It is designed to allow the tip to be placed on clean metal and drag the tip to make the cut
The highest point is the landing, or what would make contact with the plate
The second landing is the cutting oxygen orifice and the lowest landing is the preheat orifice
The tip is designed to have the preheat orifice placed in line with your cut
You would follow that direction (highest landing following the cut line, last)
The main issue surrounds the cutting oxygen orifice.
Today the smallest size tip we make is a size “0” which is designed to cut material 3/8” to ½’ thick
We have produced a size “00” in years past, that would allow cuts on material down to ¼’
This presents a problem cutting thinner material, i.e. sheet metal.
While it is possible, the kerf is normally larger than what would be desired
Torch angle should be perpendicular to your plate as you make the cut
Below is our standard tip chart. The 110 type follows the same operational requirements as our standard 101 series (end quote)
- 1 like
Guess Victor does not refer to them as Sheet Metal cutting nozzles.... but many others still do
http://www.diywelding.co.uk/?i=39922
