Has anyone used a newer inverter 211 with 100% C02? I have read the the older passport did real well with only CO2, maybe the 211 does too. Does the 211 change other electrical parameters when metal/gas knob is switched other than changing the voltage and wire feed rate used for Auto-Set.
For GMAW mild steel how much worst is the splatter with only CO2? I'm a rookie at this, only having laid crappy beads using a HF Mig 151 clone. I'm thinking of getting a 211 to improve the machine part. Would welding with only C02 be much harder to do with the skills not transferable to Ar/CO2 welding? Is trying to improve welding skills with CO2 dumb, since learning with Ar/CO2 is much easier?
Thanks.
Thanks.
