Where can I find this in 20' lengths? I am located in Mississippi and have been searching for a while now. I need 1-1/2" OD SS pipe for a long handrail. I need it already mirror finished so I won't have to go back and finish the rest of the pipe, only my welds. Anyone know of a place I can buy it?
Mirror Finished Stainless pipe??
Check with these guys.
They do electro-polishing of SS pipe (looks like chrome) but I don't recall what the length capacity of their EP tank is.MM200 w/spot controller and Spoolmatic 1
Syncrowave 180 SD
*HF-251D-1
*WC-1S & Spoolmatic 1
PakMaster 100XL
Marquette "Star Jet" 21-110
Just had to look.
7'x3.5'x4' Tank. Don't know if double dipping works but even if it does overall length will be limited to less than 20'.MM200 w/spot controller and Spoolmatic 1
Syncrowave 180 SD
*HF-251D-1
PakMaster 100XL
Most important, electropolishing will not put a mirror finish on stainless, it will only bring out whatever finish is ALREADY there. In fact you'll see imperfections you may not have seen before the process.
To the OP, if you really need 1.5" OD then its tubing your looking for, not pipe.
Try here. I used to deal with these guys when they were located in NJ. Now they are in North Carolina.
MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Lown 1/8x 36" power roller
Arco roto-phase model M
Vectrax 7x12 band saw
Miller spectrum 875
30a spoolgun w/wc-24
RCCS-14
Ltbadd, I think you're confusing electropolishing with chemical passivation. I've seen it and the process and it looks like chrome.
Syncrowave 180 SD
*HF-251D-1
PakMaster 100XL
Originally posted by duaneb55 View PostI've seen it and the process and it looks like chrome.
I am responding to the OP's request for a mirror finish.
Stainless will brighten, but it not look like a chrome bumper with a mirror finish UNLESS the pipe (or tube) was polished before the EP process.
So my point is if the OP wants a true mirror finish the tube would need to polished to a mirror finish before the electropolishing process.
Electropolishing, which is a higher forum of passivation will magnify (or bring out) whatever the finish is of the part being electropolished.
This company may have something you can use but depending on how much you need, it could be expensive.
They also have stainless fittings for the rail.
King Metals provides decorative & commodity metals, forged steel balusters, scrolls and rings, cast iron design panels, gate operators, pre-fab fencing, hinges, locks and hardware.
Dallas location is close to you.
Good luck,Miller Dynasty 350, Dynasty 210 DX, Hypertherm 1000, Thermal Arc GTSW400, Airco Heliwelder II, oxy-fuel setup, metal cutting bandsaw, air compressor, drill press, large first aid kit, etc.
Originally posted by Ltbadd View Post
You are right, however to someone who may not be familiar with the process they could be lead to believe that if stainless is electropolished it will (automatically) look like chrome. If (stainless) having a brightened finish is being referred to as (looking like) chrome then okay.
Look it up.
Syncrowave 180 SD
*HF-251D-1
PakMaster 100XL
duaneb55, I think we're on the same path here,
ASTM B912 Standard Specification for Passivation of Stainless Steels Using Electropolishing
From the link... Abstract
This specification covers the passivation by electropolishing of stainless steel alloys in the 200, 300, and 400 series, as well as precipitation-hardened alloys...
Note 1—Surface passivation occurs simultaneously with electropolishing under proper operating conditions. The quality of passivation will depend on the type of stainless steel, the formulation of the electropolishing solution, and the conditions of operation. Free iron on the surface of the stainless steel is removed resulting in improved corrosion resistance. Surface smoothing obtained by electropolishing will also improve corrosion resistance. Electropolishing will also remove heat tint and oxide scale.
Alright, I'll have to concede on electropolishing being a "higher (form) of passivation" as I was focusing on the actual finish appearance and differences of the two processes.
However, I maintain that an elecropolished finish is superior to a mechanic polish and wouldn't be surprised if the "polished" railing material the OP is seeking is nothing more than electropolished.Last edited by duaneb55; 04-19-2016, 09:49 AM.MM200 w/spot controller and Spoolmatic 1
Syncrowave 180 SD
*HF-251D-1
PakMaster 100XL
