I have a boat project that needs a new transom board...but the sheet aluminum that makes up the splash well and its supports have been welded to the transom and the stringers... trying to think of a way to cut them free, but still have the original dimensions , so they fit similarly when I need to weld it all back together.... Other wise I have to plan on a patch welded sheet or strip on the flat sheet areas... if I do that I am looking at riveting the patch sheet in place so there is a gap that represent the kerf of the "CUT".... so it is help in place as close as possible for MIG welding...which seems like a big task.... actually it all seems like a big task...on the stringer...the verticle support of the splash well... had an angled lip of about 3/4" width that was mig welded to the broad top of the stringer... the parts are not stitch welded...they welded the whole length mostly... could use some tips....if any are available
dvice
dvice
