I know these are just about the bottom of the barrel, but I got it off craigslist to do some body patchwork on my old car. My problem is that there is no voltage at the 'B' voltage position nor any wirefeed. A, C and D position are fine. The gas valve clicks on the B position. So I'm thinking the voltage rotary switch might be the problem. Any thoughts from you guys? Also, if I have to pull the switch--how is the knob removed? thx, Trenton
Newbie with a Lincoln weld pak 100
Originally posted by raymor91 View PostI know these are just about the bottom of the barrel, but I got it off craigslist to do some body patchwork on my old car. My problem is that there is no voltage at the 'B' voltage position nor any wirefeed. A, C and D position are fine. The gas valve clicks on the B position. So I'm thinking the voltage rotary switch might be the problem. Any thoughts from you guys? Also, if I have to pull the switch--how is the knob removed? thx, Trenton
http://www.lincolnelectric.com/en-us...r-manuals.aspx
Use some lemon juice on the contacts if they are corroded..make sure to neutralize it shortly after you clean them. Selector switch in my lincoln did same thing. I used a little of the spray battery terminal protector to lightly coat the parts of the contacts that don't make the contact. No idea if that's good or not, just trying to keep corrosion from coming back. Repaired mine 6 years ago. Still works fineblue stock,
miller shopmaster 300, s22a feeder, s30 spool gun, hf251, arc pig
miller maxstar 150 STL
miller maxstar 210
miller a bp 330
non blue,
Lincoln weldanpower 150 1982 model
esab plasma
Hobart ironman 210, spool gun
victor oxy acy set
thousands of snap on tools, 3 large boxes and tons of automotive equip.
