Ive got an issue coming up with my 211. It always ran fine until recently. Everything works as you would expect except that it seems as though it is underpowered. I was welding some 1/4" sheet on 230v and had to crank it up as high as it would go to make any real penetration into the metal. Had a good sounding sizzle. I thought maybe it was just a fluke with the metal but then I just tried to weld some aluminum with the spool gun and it just wouldn't work. No penetration at all. I recently cleaned the connectors for the ground so I don't think thats what it is. Any ideas what might be wrong with my welder and how I might fix it?
Not sure if this is a coincidence but I did recently do a big project where I had to run it off of 110v from a 100ft cord but the cord was quite thick.
