syncrowave 250 setup basics old style machine
  • syncrowave 250 setup basics old style machine
    Hello Group,
    I have a syncrowave 250 (new to me) with the manual dials and am looking for a Utube or some other method of teaching me the basic settings for doing tig work. It has the water cooled torch and footpedal, I have done some tig welding 20yrs ago for a Community College course on welding. None since then and this is a new type of machine for me. I'm needing to set it up so that I'm successful as I can be to start out. I plan on starting with 1/8" HR angle iron and flat stock as practice. I then want to do aluminum 16ga after I get comfortable with the equipment.
    So any suggestions ? Look forward to any and all responses.
    TX
    Mr fixit for the family
    Chris
    Look around on this site & find the owners manual download section. I added the link below. Type in your serial number to get the correct manual. This will tell you what all the dials & switches do & how they should be set.
    For starters though set the big handle to "electrode negative" which is dc- for steel tig work or ac for aluminum. High frequency switch should be set to "start" for steel or "continuous" for aluminum. Balance knob, set it to 3ish. Output switch to "remote". Amps should be set about 1 amp per .001" thickness of material. For 1/8" set about 125 amps. Arc force to "off" (this is for stick welding). Post flow about 10 seconds. Amperage control switch to "remote 14" when using a pedal. Crater time to "off" (don't worry about this for now).
    Link for manuals (it is in the support area at the top of the main page)
    Find replacement parts and receive detailed answers to your questions by downloading owner's manuals for your Miller products.
    MM250
    Trailblazer 250g
    22a feeder
    Lincoln ac/dc 225
    MM200 black face
    Lown 1/8x 36" power roller
    Arco roto-phase model M
    Vectrax 7x12 band saw
    Miller spectrum 875
    30a spoolgun w/wc-24
    RCCS-14
      Basic TIG Guidelines
      Read and understand to get you started...
        https://www.millerwelds.com/support/manuals-and-parts
        Balance knob goes to 7ish for GTAW. 3ish is for stick.
        Griff
          Griff01 - I must disagree here unless they changed this on later machines. My panel says "ac balance - set to 3 for balanced & dc welding" They even shaded the area around the 3 on the scale. Also this quote from the owners manual "Use control to change the ac output square wave for more cleaning or penetration. Position 3 provides equal cleaning & penetration".
          Here is a link to the manual. My Syncro is from 1995, KG serial #.
          MM250
          Trailblazer 250g
          22a feeder
          Lincoln ac/dc 225
          MM200 black face
          Miller spectrum 875
          RCCS-14
            This is a very basic ... easy to understand TIG intro
            Read this... then follow the tabs on the left side of the page
            TIG Welding Tips
            https://www.millerwelds.com/resource...ing-tips/setup
              Hey Group,
              The responses are exactly what I need! Thanks for the links. Going to check it out and if I'm struggling too much I may be back.
              TX
              Mr fixit
              Chris
                https://www.millerwelds.com/files/ow.../O353L_MIL.pdf
                Your words are correct in reference to your manual but GTAW does not like a "balanced" arc. GTAW likes more penetration/less cleaning. Seven (7) is the preferred initial setting.
                HTH
                Griff
                  Thanks for clarifying your comments.
                  MM250
                  Trailblazer 250g
                  22a feeder
                  Lincoln ac/dc 225
                  MM200 black face
                  Miller spectrum 875
                  RCCS-14
                    Just trying to help you understand the basics of GTAW.
                    Griff
