I pulled the welder out after not using it for about a year and seemed to work at first then I realized the gas was almost out. The first few tacks the gas flow as on/off like it should then it started flowing gas all the time. I refilled my tank hoping it was some issue with pressure but looks like its still just flowing all the time. Is this an easy fix or do I need to take it in to get services or something.
Dynasty 200 Gas does not stop flowing
Possible gas solenoid stuck open, tap on it lightly and see if it closes.
jasigpic
Millermatic 350P
30A Spoolgun
Lincoln Pro Mig 140
Hypertherm Powermax 30
14" Rage Evolution dry saw
40 ton press brake
Evenheat Heat treat oven
1x42 / 4x48 belt grinder
I'd bet $20 on the gas solenoid too. 99.99% there is crap stuck in it. I ALWAYS crack open the bottle valve before hooking it up to the regulator. Even so I just last week has a solenoid start sticking open on my small portable mig. I've also had a solenoid on my Dynasty 350 leak because the backing nut on the inlet had loosened and the solenoid was getting torqued so the valve wouldn't seat.Ryan
DYNASTY 350 w/Wireless pedal
COOLMATE 3.5
CK WF1
SPECTRUM 375 X-Treme
(2) DIGITAL ELITE helmets
Weld-Mask goggles/hood
OPTREL e684 helmet
SMITH torches
HARRIS torches
Originally posted by xryan View PostI'd bet $20 on the gas solenoid too. 99.99% there is crap stuck in it. I ALWAYS crack open the bottle valve before hooking it up to the regulator. Even so I just last week has a solenoid start sticking open on my small portable mig. I've also had a solenoid on my Dynasty 350 leak because the backing nut on the inlet had loosened and the solenoid was getting torqued so the valve wouldn't seat.Nothing welded, Nothing gained
Miller Dynasty700DX
3 ea. Miller Dynasty350DX
Miller Dynasty200DX
ThermalArc 400 GTSW
MillerMatic350P
MillerMatic200 with spoolgun
MKCobraMig260
Lincoln SP-170T
Linde UCC305 (sold 2011)
Hypertherm 1250
Hypertherm 800
PlasmaCam CNC cutter
Fadal Toolroom CNC Mill
SiberHegner CNC Mill
2 ea. Bridgeport
LeBlond 15" Lathe
Haberle 18" Cold Saw
Doringer 14" Cold Saw
My backing nut had loosened and I'm sure changing bottles, general moving around of the cart, too many tools in too small a shop banged something into it and twisted the valve inside the cover...The bracket that holds the blue solenoid to the gas fitting was slightly out of square and wouldn't seat all the way. I had to unscrew it, straighten the tabs and it's been working great for 2 years?
Ryan
COOLMATE 3.5
CK WF1
OPTREL e684 helmet
SMITH torches
HARRIS torches
